It sounds like an issue with your battery. You could try a software repair using Xperia Companion but I think it's best if you contact your Local support team for a repair.
Hi @gyangrv8,
Welcome to the community.
I am sorry to hear your device is not charging. Let's do a couple of tests to isolate the problem.
Can you please hold the power button and the volume up button, and tell me if it vibrates?
Your local repair centre has specialised tools that will help them open the device and replace the battery.
