Xperia Z3 battery not charging
gyangrv8
Battery wa around 55%.After half an hour I saw it was switched off,when I switched on,I saw battery was 4% n it automatically got switched off.Again I switched it on and I saw battery was 3% n again it automatically got switched off..I put it on charging,it took charging twice but again stopped within seconds and after that it's not charging at all..What should I do?? Please help me.
CameronT
@gyangrv8,
It sounds like an issue with your battery. You could try a software repair using Xperia Companion but I think it's best if you contact your Local support team for a repair.
8 REPLIES 8
CameronT
Hi @gyangrv8,
Welcome to the community.
I am sorry to hear your device is not charging. Let's do a couple of tests to isolate the problem.
Can you please hold the power button and the volume up button, and tell me if it vibrates?
gyangrv8
No..it doesn't vibrate
CameronT
@gyangrv8,
I see. Can you please test other cables/chargers?
gyangrv8
No response from the cellphone at all.
gyangrv8
@CameronT,
What problem do you think might have been?
CameronT
@gyangrv8,
gyangrv8
Battery is non-removable so how battery will be replaced???
CameronT
@gyangrv8,
Your local repair centre has specialised tools that will help them open the device and replace the battery.
