Hey!
Did you tried the way I described? Seem that later, people did some modified steps.
Bojevnik
Don't know than. Worked for me on my Z1 compact. Maybe, it has something to do with updates?! Try with this (uninstalling updates of this two applications then go through procedure) before factory reset.
I found this and it worked for me:
On Settings -> Applications Manager -> All tab -> BadgeProvider -> Clear Data
Restart your phone and the notifications should be back to normal.
This is exactly what's wrong but I can't get into application management or badge thing. They aren't there
One more thing you can try is to download this app and see if you have receieved any message from an unknown sender. In that case, try deleting those.
Thanks, this did the trick!!! So annoying though!
