Unread message essage badge error
Rockfletch3000
My stock message app and notification centre are both indicating that I have 1 unread text message. A little yellow number '1' badge is showing on my message app icon on my home screen, and also my notification centre says 'New Message' ..... but I have read AND deleted ALL my messages! Is this a software fault? I have tried deleting message data, cache and removing the app icon from my home screen but this error will not go away... Please help.
PMFG
I am having an identical problem since the last software upgrade, and have tried all the steps mentioned. No luck. Seriously annoying. Let's hope the next upgrade fixes this while I use Hangouts as the alternative in the meantime!
44 REPLIES 44
profile.country.RO.title
_alexdon_
Have you tried to restart your device?
alexdon
Rockfletch3000
Hi, yes restarted my Z2, deleted message cache and restarted, deleted message data and restarted, removed icon from home screen and restarted... Text myself and restarted... Tried everything I can think of apart from factory reset...
_alexdon_
Thommo
Genius
Not sure this work or even if you have tried but open Settings then Apps and swipe to all then locate and open Messaging - Tap on force stop, Disable, clear cache and data maybe not in that order and then reboot
Rockfletch3000
Hi I tried safe mode and its still saying I have an unread message!
Rockfletch3000
OK Thommo I'll give that a try now...
_alexdon_
If none of the above help,try to look through your messages,there might be a chance it goes away.
alexdon
Rockfletch3000
You the man Thommo! Did exactly as you suggested and the irritating little number 1 is gone! Just hope it doesn't come back because I Dont want to have to keep deleting messages. Thanks for all the help. : )
Thommo
Genius
Don't forget to mark the correct answer and if you found any answers helpful then click the kudos button
oh and glad you got it sorted
