Weak Wi-Fi signal after Android 6 update
Ali34
In new version of Android 6 z3 the phone speed very low and signal wifi very weak is very bad please fix the bug
Tags (1)
profile.country.RO.title
_alexdon_
@Orfeas@Ali34@Paschouale@Budulis9999 and everyone else
.575 update on Z2 seems to have fixed the wifi indicator that was showing a lower signal, so Z3 should be fine now too. I will try to get some info on this by next week.
alexdon
69 REPLIES 69
@Ali34
Could you elaborate? Do you experience the same while on >>> safe mode ?
Rickard
You might experience that the Wi-Fi coverage in the Xperia Z3 and the Xperia Z3 Compact appears to be weaker than before the upgrade to Android 6.0. However, the reception is not weaker. It's only a perceived Wi-Fi coverage downgrade, due to a bug in how the Wi-Fi bars are calculated. This is a known issue which will be corrected in an upcoming software update.
Could you elaborate on how the phone is slow?
Jack03
after new android update, the z3 my sony wifi worse start. Who met the same problem, may I know how to fix it
@Jack03
Could you elaborate on the issue?
saleef
Hello,
My xperia Z3 WIFI stregth has found to be reduced after marshmallow update, wifi signel disappearing frequently from my Z3 ( while my laptop and tab dosnt have any problem with wifi signal ).
anybody has the same iisue ? how to fix it?
Thao91
Same question
DanielLee
I just got my update i am having the same issue. I dont want to repair or reset my phone
Jack03
wifi catch poorly than android L
Christofer
@Jack03 Please see Rickard's post earlier in this topic.
