Xperia Z1 Black Screen, Completely Dead already ! PLEASE HELP !
TheCustodian
I pressed the power button to bring up the phone, it came up for a second and then suddenly jolted to Black screen. The screen is permanently on but its black and I cant do anything! Cannot even do the hard reset ! This is unbelievable I've had it 3 days ! HELP PLEASE !
199 REPLIES 199
profile.country.IT.title
dynax73
New
UNFORTUNATELY disabling adaptive brightness and optimized backlight do not resolve the "display won't wake up" problem.
it happened rarely but happened Slightly_frowning_Face
I also tried to activate photography mode by pressing the physical button, no way to turn ON the display Slightly_frowning_Face
Phone goes in photo mode but display is turned always off...
Please Sony fix this BIG problem!
(actual firmware .534)
Tags (2)
GeoffH
Enthusiast
I believe the display wake up issue is to do with the auto brightness as I explained in an earlier post, the screen actually wakes up but it is so dark you cannot see it - this is because the auto brighness range or scale is dependent on the position of the brightness slider before you activate it - so if the brighness is manually turned right down as far as it will go then you activate auto brighness it adjusts the brighness so low you cannot see it - it is a bug and needs some attention
lcoperfield
@H4rry wrote:
I'm glad i joined this forum before purchasing a Z1 it's kinda made my mind up to stay clear of this model very disapointed:smileysad:
Z1 rocks and the problem is clearly software related. Don't get dissapointed because of this... The camera and generally the "feeling" that Z1 gives you when using it is amazing.
learndotnet
New phone 5days old.
No BT on.
Latest update(1.534).
Screen went black, but i could still hear the sound when pressing buttons, or the phone did ring when i recieved a call.
I had to reboot.
I will try to send back the phone and go for another brand if there is no quick update.
jun
WORKING SOLUTION: enable BACKLIGHT OPTIMIZATION in the setting under the Diplay menu...worked and tested so many times..yeeha....
jayashanth
Hold volume up and power button until your phone turns off and then power on normally.
learndotnet
No this is not working for me, this was on when the bug happened.
emmern
This just happened to me, and bluetooth has always been off. I have had it for less than a day... I hope it does not happen more times. Because if it had been an emergency and I needed to call - well - it would be unforgivable.
dacica
takuhii
Hopefully this fixes it, I'm on 534 and I still get this problem Slightly_frowning_Face
