Please help. How can I set different ringtones for different groups of contacts (family, coworkers, etc)??? (Sony Xperia ZR)
I can set individual ringtone for each contact. In case of setting ringtone to the group of contacts it doesn't work right - the ringtone still is the standart one, which was set in the general settings. Please help, I would be very thankful!!
Same problem at Xperia ZR.
Alexander, Sony Xperia Support, where are you? Please admit and fix the problem.
Could you please send me your details in a PM, and I will forward this.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Product(s):
IMEI nr:
Build number:
I do have the same problem. It doen't work in any way... local contact, sync contact... Could you fix this asap?
I don't even see the option for changing ringtone for group. Only for single contacts. Or am i blind?
I have received more information and unfortunately this feature is no longer supported. The option in the menu will be removed in upcoming updates. You will still be able to set a ringtone for a contact though.
Rickard
Thank-you for the confirmation that this feature is no longer supported - at least I can stop trying to work out how to do it now.
It would appear that I am not alone is using this feature - i.e. assigning a ringtone to a contract group. It is something I have used heavily for many years now on several different brands of phone.
Can you please pass this on to the appropriate people that the user community would like this feature reinstated? If you are unable to do so, please advise the means through which I can raise this request to Sony.
I must say I am surprised that Sony has chosen to remove this feature from the Xperia Z1 without any apparent consultation with its customers.
Regards
Gary T.
I already passed this on as feedback but i'll do it again.
I downloaded exDialer to see if I can set ringtones for groups. Although it gave the option, it never actually worked.
Hi Rickard,
Could you kindly please pass on another suggestion please?
The option to assign a ringtone for callers who are not in the phonebook contacts.
Thank you.
