ringtone for the group of contacts
ShOlly
Please help. Slightly_frowning_Face  How can I set different ringtones for different groups of contacts (family, coworkers, etc)??? (Sony Xperia ZR)  Crying_Face
I can set individual ringtone for each contact. In case of setting ringtone to the group of contacts it doesn't work right - the ringtone still is the standart one, which was set in the general settings. Please help, I would be very thankful!!
Tags (2)
23 REPLIES 23
Alexander1
Just to clarify, how have you set a ringtone for the group? Did you go into contacts > group > press a group > edit > press the ringtone option and change the ringtone?
Is it  local contacts or have you synced your contacts to your Google account?
ShOlly
Yes, just as You say
contacts > group > press a group > edit >  and the second row allows to choose ringtone (the first row-the name of group) and also here I can see button "add members", nothing more
I tried it in both ways, as local contacts and as synchronized to Google accounts. It doesn't work anyway =(
raverke95
I discover the same issue with my 3 weeks old Xperia Z. It's also a very usefull feature for me.
Does someone has a solution for this?
57
Group Ringtone setup never works on Xperia Z. Sony, Please fix. Thanks.
raverke95
nice bug, thanks Sony Broken_Heart
Arindam_007
Can we please get a confirmation if this bug has been posted for correction. Please fix this problem or give us a work around.
Goateye1
The workaround is named the app DW Contacts & Dialer.
If course, there are other similar that works as well. But stock does not work...
Arindam_007
Thanks Goateye! But we should not have to use another app altogether for a bug like this! It's a very basic feature and a very apparent defect in almost all the Xperia versions it seems! Sony please correct this bug! Please confirm if the issue is reported to the Dev team!
Suezawy
how could sony bypass this basic feature, sony should give us any solution for that bug
