my XU had gingerbread on it
even then it consumes a lot of battery
i have to charge it almost thrice to four times a day
even in the night, on standby, it consumes 25 to 30 of the battery which i check the next day mornin
can anyone suggest me some solution for it
maybe some app or anythin which will help
and if i upgrade to ICS then will it solve the problem by Sony's Extended Standby Mode ???
ok
i did a setting reset
and it didnt affect my XU battery life
it was as usual
and then i went for factory reset
and ohh god
my battery life has degraded like hell
on standby it eats almost 10 percent in half an hour
after texting for an hour
it lost 40 percent
what am i to do??
use ur phone n discharg it to around 2% and then completely charg it to 100% and aftr that restart ur phone...even try dis: after discharging to 50% charg it to 100% n dn restart ur phon n then use it...
i saw lot of change in battery life due to it...u try too..
ok
i ll try
and i ll also post the screenshots of the battery usage screen
and how do u repair ur original phone software usin PPC or SUS ??
Guys, battery draining isn't caused by OS, but by running apps. Reinstalling of ICS doesn't solve this problem, if there is running what is running (integrated OS-apps or any custom app(s))
reinstalling will help any driver glitches if there, but nothing more. try to remove bloatware or disable them.
Please mark Correct and Helpful answers and you can also visit my blog at:arnabghosal1989's Blog
Hi
It is very clear that battery drained because of phone signal......
For any mobile if netwok is not available it keep on searching for mobile network it results in huge battery consumption.
What to do
1. charge 100%
2. Be in area where signal is strong
If still battery drains then u have to check for another solution.
