Pairing Questions
intrados
Pairing Questions
Hi, I have  WM1 and WM600 as well. For my unpleasant surprise, WM1 could not be paired to my "old" devices as it uses only smart pairing with 6 digitits, while I need standard way with 4 digits. Any was to pair device with classical pairing by entering 4digits pin? WM600 has no problem with it.
Second topic is that WM1 memorizes only 2 devices while WM600 does 3 or 4. Could development team add this funcionality?
THanks and regards
Rado
3 REPLIES 3
Johan
I will pass this on to concerned project. Thank you for sharing your feedback.
Mr_Lu
hello, enter “0000” as pairing code, then Smart Wireless Headset pro should be able to handle this code, but no need to enter it in the headset itself.
Good Luck!:smileysilly:
Johan
I just got an reply about this and MW1 supports both 6 and 4 digit passcodes.
