my XU had gingerbread on it
even then it consumes a lot of battery
i have to charge it almost thrice to four times a day
even in the night, on standby, it consumes 25 to 30 of the battery which i check the next day mornin
can anyone suggest me some solution for it
maybe some app or anythin which will help
and if i upgrade to ICS then will it solve the problem by Sony's Extended Standby Mode ???
depends on local laws. In India I think if you give your mobile to a repair centre, there are chances it will get more dmged.
Please mark Correct and Helpful answers and you can also visit my blog at:arnabghosal1989's Blog
arey wat local laws? im gujarati....in india.....
ok thanks...
and found a new launcher vry cool.....
--tsf shell
--qq launcher
both are very fine
thanks for the information. What is the problem with ur phone, try to solve it yourself, I dont trust the repair people.
yup i knw evn i dont trst them....
ty...
tell me about the launchers...
my xperienc:::i went to service station wid my psp...its laser head was not moving...only dat was d problem even then sony officials said that they cant replace it..pay 75% of the original price and take a new one...
they jst cant servic the laser head motion....at that time i was lik wanted to play GTA and blow d offic...
lol.
they most probably lost the warranty.
Dint understand wat u said....who lost d warranty?
in our xu hardware and software warranties are different right?
Hey i switched on only gsm mode but still my xu consums 30% battery at night when data is off n all processes too...
by switchin to gsm mode in ur xu d problem is solvd?
Ady, try this :
- charge your phone to the fullest
- make sure you leave it in a place where your signal strength is maximum not alternating, over night (check and double check)
- check in the morning how much battery drained over night
- do it all over again with different features enabled (data traffic, GSM, etc)
Trust me when i say that signal strength makes a ton of difference when it comes to battery life. Mine ranges from almost 7 days to 1 day (if the signal has problems)
i had also a battery drain problem, had to charge everyday without almost not any wifi usage or other heavy usage. Checked the battery status and 78% was the screen which i didnt understand. Anyway how i solved is by only resetting the phone settings and now after charging yesterday its still on 90% with daily usage
Reset settings
not factory settings
