Is there a planned fix in the works for the camera? Presently, the video camera is useless as it stutters and lags horribly. The only video mode that doesn't stutter is Mms which is grainy and low res.
Whenever I run the camera, I ensure all other apps are closed; in case it is a memory issue. I've tried rebooting it and disabling services to no avail.
The still camera also has issues now too. The camera never properly focuses. Each time I try to take a picture, the camera properly focuses in the viewfinder and then takes a blurry picture.
The camera worked fine prior to the last update. I've tried using Google's camera which records okay video, but had the same trouble taking still pictures.
Please help!
I have the same problem, pics i made last week 100%. since the update horror.
In save mode, the same.
Sony fix this, in 14 days i go on holliday and i need the cam!!
Sony,
I know it is a separate issue, but here is what my backup program does. The first 50% completes in about one minute. I've left it at 50% for hours and it never finishes.
Cameron,
I just ran the software repair as you instructed and it did not fix the problem. The still camera still takes fuzzy pictures and the video camera is atrocious. The video camera is only taking about 1 frame every 5-10 seconds. This is after a fresh re-install and is exactly as it was in safe mode. This problem did not exist before the last software update.
Adam
...And the backup/restore program through PC Companion didn't work right either. It claimed it restored everything, but I lost a lot of my apps and customizations. I might as well have started over. This is getting to be a real pain.
My phone is in even worse shape now. My work email will no longer synchronize. It restored the account, but told me the password was wrong. If I go into accounts, under settings, it's not there. When I try to add it again, it fails each time. At least before, it was just my camera that doesn't work. This really !
