Hi all,
I have problems with my WiFi speed. First I found youtube to load videos quite slowly. After that I used "Oookla Speedtest" to check network speed. I have 6MBit DSL-connection at home, but if I use the speedtest after the WiFi has been switched on for some minutes, I only get ~1Mbits on the Xperia Z3 compact. If I switch WiFi off and on again on the phone, I get the expected ~5Mbits. This happens not only at home, but also at work and at my parents house. WiFi router types are different in all the 3 places.
The problem persists even If I stand 1m away from the router. WiFi reception is shown to be very good on the phone. My old iPhone 4S does not have this problem. Since turning off and on WiFi on the Z3 compact solves that problem for some minutes, I blame it on the phone itself. I already tried turning off and on the phone, as well as factory reset. Problem persists. Any hints?
Thanks a lot!
Hi
I've had the new X3C for three weeks now and also noticed how the youtube app was slow in downloading video clips, yet when I switched for 4G everything ran smoothly.
I have to be honest, I cannot follow all the discussions on this forum thread - too technical for me! But if somebody could explain to me how measure what speed my wifi is at home with my phone, that would be a good start - much appreciated.
If there's an easy solution to this please let me know.
Kind regards
V3RGY
Hi V3RGY,
search for "speedtest.net" on the playstore. You can use this app for testing your wifi speed at home.
The wifi was bad on my old z1 compact...and my friends... and its **bleep** yet again with my z3 compact and my friends z3 compact tablet.... whats wrong?
If your problems disappear when you switch off mobile data, after that disable and reenable WiFi again, then there is nothing else you can do but to wait for an update, as ist is not a particular problem of the Z3/Z3C, but an Android problem in general. The bug is fixed in the Android repository, but seems as it not made its way to release yet. Switch mobile data off while you´re on WiFi, that helps as the problem is directly tied to the mobile data network.
If your problem persists after switching mobile data off and toggle the WiFi, then you might have a different problem.
Hmm, I think my phone has another problem. None of the solutions get my wifi working regularly. Even worse, my mobile data has stopped working too. It stopped working last night, and this morning I did a factory reset and it worked for about 20 minutes before failing again.
The cause of this has been identified and is fixed in the next SW release (23.0.1.A.5.xx).
Thanks again noize for testing and providing us with logs.
Hi there rickard
so are you saying that the issue has been resolved now and will be fixed in the next update?
when can we expect to see the next update roll out?
regards
Vik
Yes, the issue has been fixed but i don't have any information on when the update will be rolled out yet.
Rickard
Thanks for replying
This is a huge relief to see the issue has been found and resolved, i can now relax in the knowledge that this problem was not just for my handset and can now look forward to using the handset with full speed internet connections with this issues cropping up.
thanks for all the guys on here that have tried to reslove this in various ways especially Noize.
look forward to chatting with you guys on future issues regarding our handsets
