WiFi - Exclamation Mark!
shaan123
Hey guys this phone is amazing and is working fine, however ever since I got it my WiFi has had an exclamation mark next to it all the time, whether I'm hooked onto my home network, or my work network. The wireless works perfectly fine, extremely fast etc. However it's just a little annoyance as the exclamation mark is always there, even when mobile data is disabled?
Any help?
37 REPLIES 37
selalerer
A solution that worked for me, I connected to my home router and changed its DNS servers to be Google's DNS servers (8.8.8.8 and 8.8.4.4) instead of getting them automatically from the ISP.
For completeness:
My situation was that I had the exclamation mark (even when scanning) and had no Internet. My laptop was connected to the Internet without a problem.
My phone is D5503
Android version is 5.1.1
ArturSampaio
Rickard
Until this moment I have only regrets about my Z3+ purchase.
The worst problem is that my phone bill increased because the comsumption of 4G data has doubled, and I can only put the blame on the wifi status with exclamation mark.
I tend to agree with CaioBRZ, but im not a hard/software expert so... what can I, a regular person, do to fix the problem?
Turn on and off the mobile or the flight mode everytime isnt an option, neither is to forget and reconnect the router from times to times. I need something easy and definitive.
Rickard
@ArturSampaio
Sorry to hear that.
Could you elaborate on what happens a bit more in detail? Do you always see the exclamation mark when you use WiFi? Does it happen with a specific network or is it any network you connect to?
ArturSampaio
Rickard
For instance: the two networks I use more frequently are my home's and my work's and they are both saved in my Z3+, but everytime I arrive here or there the exclamation mark appears beside the wifi signal, which doesn't work.
Sometimes - only after a few minutes - the exclamation marks disappears by itself or the smartphone changes automatically its connection to 4G, but much more frequently I have to turn the wifi off manually and choose between turning it on and off a few times hoping to force the connection or simply giving up and start using the 4G - this way my phone bill has increased a lot since I bought the Z3+.
I have already asked to my work's IT staff to set properly the wifi connection and changed my home router settings several times, but the problem remains. At home the Z3+ is frequently aside and I'm mostly using my old Samsung S4.
Thanks in advance.
Artur Sampaio
radhabordia
My phone and Laptop is also showing this exclamation mark and there is no internet connnectivity. The internet works fine when i attach the LAN cord to my Laptop. which means there is a problem in the  WIFi Modem. The WIFI modem glows all the required lights. any help ?
Rickard
@ArturSampaio
Do you have Stamina enabled under Settings -> Power management? If so, could you try to turn it off and see if that helps.
You may see an exclamation mark on the WiFi icon just after the phone has got a connection. The phone will display the exclamation mark until it got a contact with Google servers. Then the exclamation mark will be removed.
@radhabordia
As you also see this on your PC it sounds like the cause in your case is the router/modem.
We have some suggestions on what you can check in this thread: http://talk.sonymobile.com/t5/FAQ/Wi-Fi-problems/m-p/348104
If these doesn't help i recommend that you contact the support for your modem/router instead. How you configure it will depend on brand and mode so i'm afraid it's hard for us to say how you can solve this.
Mollysgirl
Samuel thanks for the information. Where on my Google do i find the DDS1 and DNS2?
Rickard
@Mollysgirl
DNS1 and DNS2 are usually specific for you internet service provider so normallt you get these by contacting your internet provider. But you can also try using a public DNS like Googles: https://developers.google.com/speed/public-dns/
It's however not certain that you can use another DNS than your internet providers.
Alwaer
I own device Sony Z5 dual E6633 I suffer from the problems in the connected the Wi- Fi home in that it relation to There are no Internet with a exclamation mark on the Wi- Fi and I went for Communication local in my country
where they said to me that the problem lies in the mobile phone Z5 is not of modems. It is really annoying to buy a new device in which the problems in the Wi- Fi. Note that the modems is one of the Company Seowon Intech. Model: swc- 300B and Model swc- 9100 note that I am you many of the settings and change the Ip and many others in vain, I hope of Sony version Reload this solve the problem as soon as possible. or any one can help Thank you
Lefter_K
For those that exclamation mark keeps breaking-balls πŸ™‚ delete hosts... It surely works. If you don't have root then u must factory reset πŸ˜•
