Ringtone volume lower than music volume
Anshul5428
There is problem after the 6.0 update while playing music the speaker sound is louder and while incoming calls if the volume is full then also it's sounding very low it's was not in lollipop.this is the bug I have checked 10'times updated my phone reseted then also it's not sounding higher alarm sound is higher than the incoming call.caller ringing volume is so low that u can hear if it's ringing beside you.please fix this.
Topic edited by Rickard
Rickard
@Anshul5428
It's normal that the ring volume is lower than the music volume. This is because the earspeaker (top speaker) will use a lower volume for ringtones. As i understand it, this is for safety reasons in case the phone should ring while you hold it to your ear.
It was this way in the previous software versions as well.
70 REPLIES 70
@Anshul5428
Just to clarify, are you saying that the ringtone volume its too low if you receive a phonecall while playing music
or
that the ringtone volume its too low disregarding of playing music.
Anshul5428
no problem is when play music speakers sound perfect and loud.
but when an incoming call come ringtone sound is very low while the volume of ringtone is set full.
while playing an alarm sound is perfect its only when call come.
for you try play music with volume full and hear sound. after that set ringtone volume full and call on ur number compare sound its will be low.
@Anshul5428
That's how it's intended to work
AhmadHaikal
I have recently update my Xperia Z3 D6633 to Android 6 and found my device ringtone and notification is very very low can parely be heard music sounds is good testing speaker through test is good checking the ringtone through sounds is good but when there is an incoming call the sound is very very low also speaker volume during calls is very low!!!!!!
Rickard
@Anshul5428
AhmadHaikal
Yes but when the ring tone has become very low that you can barely hear and the ringtone at maximum this odd and it wasn't like that before marshmallow update even the speaker during the call became very low as well like it's not there
Anshul5428
Its does not work like that before the update the sound was perfect its only after the update when this sound problem arise not only in ringtone in loud speaker also when we are on call then turn on the loudspeaker that also sounds very very low compared to lollipop update.this bugs are in marshmallow only
Anshul5428
the ringtone volume its too low disregarding of playing music its was much higee in lollipop and kitkat
exsanguinator
How much worse can it be?
Im still on kitkat and the ringtone is still too soft
