There is problem after the 6.0 update while playing music the speaker sound is louder and while incoming calls if the volume is full then also it's sounding very low it's was not in lollipop.this is the bug I have checked 10'times updated my phone reseted then also it's not sounding higher alarm sound is higher than the incoming call.caller ringing volume is so low that u can hear if it's ringing beside you.please fix this.
Topic edited by Rickard
If anyone still curious about fixing that quote safety option! I get around that by using app from Google play named macrodroid!
So i made a Macro which play music when call incoming, and don't forget to use none ringtone from the system settings.
So now i can hear my z3 ringing 😀
The only thing that I still trying to overcome is that the music continue play with very low volume while the call.
But it's OK, so low n you only can hear it. 😊
Best wishes
