Ringtone volume lower than music volume
Anshul5428
There is problem after the 6.0 update while playing music the speaker sound is louder and while incoming calls if the volume is full then also it's sounding very low it's was not in lollipop.this is the bug I have checked 10'times updated my phone reseted then also it's not sounding higher alarm sound is higher than the incoming call.caller ringing volume is so low that u can hear if it's ringing beside you.please fix this.
Topic edited by Rickard
70 REPLIES 70
Rickard
@Anshul5428
That sounds strange. Do you know if you had any 3:rd party app or similar to increase the ringtone before? The volume from the top speaker has always been lower when the phone rings For media (and also when you select ringtone), the volume from the top speaker will be higher. This is not new for the Android 6 update.
Also check if there may be any dirt on the bottom speaker and try cleaning it carefully. As you mention lower volume also when using speakerphone, it sounds like it's the bottom speaker that giving a lower volume.
AhmadHaikal
No 3Rd party app was used also dirt on the bottom speaker also has been cleaned the speaker is working properly but when there is incoming calls only it becomes very very low
AhmadHaikal
Please any one got solution for this issue why sony support doesn't care !!!!!
exsanguinator
It may sound soft to us, but it probably is still within the accepted db parameters of sony engineers.
After all, in a dead quiet room, late at night,I can clearly hear my ringtone.
Riyakhusi
I am also having same problem after updated to 6.0 caller ringing is very low very much disappointed after updated my phone 😞 plz do sumthing on next update,pls fix this
mid0o0
Dear,
I have the same situation after marshamellow upgrade the speaker sound become too low as i can't hear and the ringtone also lower than the normal before and the mobile delay during making call and choose the sim which i want. I tried to make software repair but no result the situation same same as before So i need your help
Ninalina
Same here. Ringtone last week was fine. Now I can barely hear. Notifications volume is fine, movies and audio as well. I've been missing important calls the whole week.
exsanguinator
I've found a workaround for this problem.as I found missing important calls very expensive and frustrating.
My wife just got a Huawei Mate 8 with a free Huawei smartwstch.
Her ringtone on thst fone can be heard next door.
I'm now using the watch with android wear on my Z3,
the watch vibrates and rings when calls are received
the watches ringtone is about the same as my Z3,but because it's on my wrist, I can hear it clearly and never miss a call.
So,since Sony hasn't done anything about this ringtone problem, I suggest to either live with this issue, invest in a smartwstch or buy another brand phone..
This will have to do for me for the next 12 mths, when I'll be eligible for an upgrade...
can anyone guess if it will be another sony fone or not?
RHMA
Hello
I own a xperia z3 phone and recently I updated it to marshmallow
And once I updated it, the sounds in my phone have gone really low!
I can't hear music, or the person I'm calling, and even the sounds of incoming calls and notifications!
Does anyone have a solution for this kind of problem? Please do help me.
And thank you
HANS_MZ
Z3 Compact the same problem , developers generally think about something?
