my phone automatically shut down when I make a call
felqalb
My Xperia z c6602 automatically shutdown at some times when I make a call, And some times don't automatically shutdown.
I make hard reset from the software, also I flash another roms but the problem is present at all of them.
The problem occurred after one week from the sudden drop from my hand.
Tags (2)
felqalb
The problem was solved.
By replacing the battery by a new one.
After searching for the problem, I find that when lithium ion batteries are heated to a certain limit the reactions in the battery stops automatically when a heavy load occur on the battery by voltage rapid drainage due to call.
I think when the phone opened, service center use excess of temperature to separate back cover from glue so the temperature increased in battery, this process is irreversible and battery must be changed, however actually it's in a healthy and excellent state.
24 REPLIES 24
@felqalb
There you go, that's most likely the cause of this, a hardware issue, contact your Local support to get it inspected.
felqalb
Is the problem with antenna or with motherboard
@felqalb
No one will be able to answer this question unless they inspect the phone, sorry.
felqalb
But there are another problem,
Battery drop suddenly after 60% after i turn on again it can drop to 15% or less
felqalb
And i changed sim and insert data sim i face another problem,
Phone doesn't turn off automatically but network signal disappears automatically for a while and back again without any action from me
@felqalb
That could be due to the drop as well, just get it inspected ASAP
felqalb
Sorry to hear that,
What you mean by "ASAP"
@felqalb
ASAP = As soon as possible
kryss782001
Hello,
my phone automatically shut down when I make a call,since it was in service for replacement headphones (5 times stopped).
Since I bought the phone is the first time something like this happens.
I reinstalled the software, return to factory settings and nothing.
