FM Radio, unable to tune radio channel
gtop
I can't tune a single channel with the FM Radio app, no matter what  headset I try (all of which worked fine with the Z1C). Changing region, resetting app data, full factory reset, repair via PC Companion = no change.
Anyone else having problems, or do I have a dud? I'm dreading it's the same problem as this one reported by Z1C users and that I can expect the same terrible repair service as described by them:
http://talk.sonymobile.com/t5/Xperia-Z1-Compact/FM-Radio-died/td-p/590479
Please Sony tell me no (and why oh why didn't I just order from Amazon).
Hampus
I've just tried it and it works fine for me. If you have tried all these things that you mention, I suggest that you contact your retailer and/or local support team for further information about how to proceed with this in the best possible way:
33 REPLIES 33
Hampus
gtop
Thanks for the reply, I tried it with a new unit and it works just fine with that one, so the original will be going back.
Pitit
Hello yeah i just bought Z3C for a week. and now my FM radio CANNOT WORK! its work great yesterday and now its stop functioning. OMG this is so frustrating.
Pitit
OK i Got a Solution The reason why  this happend is because i activate "OK GOOGLE"  function. now after i deactivate this function surpisingly my FM Radio WORK WELL... i hope SONY will get this fix ASAP .. and one more. if i activate OK GOOGLE .. one notification "Recording in progress in another app. Cannot record" suddenly appear when i open camera... yeah this is very frustrating...
Kaminari
I also tried all the Software-Mojo. Nothing seemed to work.
Then I just went out to try if it works outdoor. It did work, but very very bad. Had to fling around the cable of my earphones just to get a notion of a FM Station I could receive perfectly cleear indoors with the same earphones but my old Samsung Galaxy Ace2 or my even older MP3 Player SanDisk Sansa Clip...
Google Now was never activated...
32321983
I have same problems in radio
serbanra
Yesss, this solved the problem for me. Go to Google Settings and change "Ok, Google" activation in any screen!
Thank you Pitit!
kmank
You sir are a genius!!! Kudos for you!!
ebadrmo
MAN you are genious!!!
It worked after OK GOOGLE disable. very strange issue...
