Battery replacement
9496
Battery replacement
Is z2 battery compatible for z1 mobile
Both are of same size and same specs almost
So I wanna use z2 battery
Jake-SonyXperia
Hi 9496,
Welcome to the community.
The information supplied above is good advice, however, I would suggest using an authorised repair agent to do the replacement and source the appropriate parts for you.
They are equipped to perform this repair and are able to keep the phone's water resistance rating.
Please use my signature below to find correct contact details for your country.
4 REPLIES 4
YoGem
Leader
Although the specs may be almost the same they are different and each controller manage them differently, in few words... Don't.
Use a Z1 battery for a Z1 and a Z2 battery for a Z2.
A simple search on eBay can enlighten you even more.
Jake-SonyXperia
Hi 9496,
9496
Plss give contact num who could do this repair
Jake-SonyXperia
Hi 9496,
I am not sure if you managed to find the number, if not please use the hyperlink below.
Contact us
I hope it all works out for you.
