Battery Issue on Xperia Z
9355
Why My screen eat Battery 45% ??
when i fully charge the battery and  i keep in network mode do nothing with it ... the battery go down fast ..
Can anyone help me to slove this problem
profile.country.RO.title
_alexdon_
Normally,the display will drain most of the battery.It is normal for it to have 40-45-50%,even more.The problem is you might have other apps acting up.Could you post a screenshot from settings-power management-battery usage?
alexdon
12 REPLIES 12
_alexdon_
alexdon
9355
I have factory restore And the screen Eat only 30% of the battery but i want to know one more thing ... i notice that Kitkat 4.4.4 is slower that 4.3 what should i do to solve this problem ??? moreover when i test the camera only 5mn it's get 3% of the battery ..
Can u anyone tell me The Life time battery of the Sony Xperia Z Like Browsing the web, Video, Music, StandBy, Talk phone,  if i use Wifi ?? and 3G please tell me Slightly_frowning_Face
9355
yesterday i fully charge the battery100%  and i just standby it and then i sleep when i got up battery is 88%
i go to battery usage i saw andriod System Eat 85% of the battery .. Why ?
Sam
Legend
Legend
Only loosing 12% overnight is not bad, I wouldn’t be too concerned about that at this stage.
What are your thoughts about this forum? Let us know by doing this short survey.
ValeRoma
Same issue here, i think i'm going to repair firmware even if i don't believe it will work..
NirmalSitaldin9
Since I updated my Z to 4.4.4 my battery life has worsen! I factory resetted my phone and it improved a liiiittle bit! So I'm a little relieved now, but what caused the battery draining issue? And overheating also
ValeRoma
Hello to everyone! I really hope that someone will help me, i am sure you have experienced the same issue too.
I haven't updated my XPERIA Z to android 5 because i am reading here that it causes a lot of issues and i don't wanna try to fix using pc companion as always.
I have Android 4.4.4 and my device overheats very fast and battery drains too much, i use smartphone only 1 hour with display on and it goes from 100% to 14% in few hours.
I disabled any notification, sync, extra or third party processes and i always "close" background apps or processes, free ram is always more than 1 gb.
I really don't know what the **bleep** let my battery drains that fast, percentage level decreases by 1% every 2/3 minutes and even if i have stamina mode and nothing on (I always disable cellular data and wifi) i cannot use device because it looks like a countdown to 0%...
Obviously i already repaired software via pc companion several times before the lollipop release and free storage is more than 10gb.. there is nothing active that could drain or overheat battery but unfortunately it happens!!
is there any app or valid diagnostics to check battery health or consuming processes?
THANKS SO MUCH
Hashim97
I think it is the Google play services
Look in settings> battery usage
Solution :
Always Turn off location and don't use it unless you really need it
Open settings >apps
Under "running" tab
Open all the "Google play services " and "Google services "
And stop everything in them until they disappear from the running tab
Reboot you Xperia
You will often need to repeat these steps if you turn on location for a long time
ValeRoma
Thanks for help man but i really never enable location services unless i need it to use maps! It is always disabled and i always close "google play services" multiple times from "running" tap...  Battery usage is mostly screen (44%) and Android system usually eats a lot too, about 15%..
I really use this smartphone so little and battery decreases too fast, diagnostics tool with hidden code says "good battery" but i think it isn't 😕
