Didn't think I would be back so fast, but I have another issue that suddenly started happening.
Checking to see if anyone else has this issue, or if there's a fix,or even if it's a known problem.
My auto-rotate stopped working. Was working fine the last 24 hours, give or take. Which is the duration of how long I've had the device.
I checked all the settings, and googled around, so I restarted my phone, now it works again.
Didn't know about the diagnostic tool until after I rebooted the device and it started working again.
If it stops working, I'll definitely run diagnostics.
But until then; known issue? Anyone else experience the same thing? A permanent fix?
-voltagetweak
I'm sorry to hear that
I see you recently were in contact with your Local support about this as well and as i understand it, it the accelerometer didn't work when you tested it in the phones service test menu? If the software repair didn't help i recommend that you contact them again for assistance with having your phone sent in for repairs.
Hey Guys
Issue Fixed, as @Rickard was mention, marshamallow update solved the problem with my Z5.
Thanx....Hope everyone's issues solved as easy as mine.
@kc1174 , try a factory reset, marshmallow update supposse to fix the problem (Auto rotation), worked for me!!!
