Didn't think I would be back so fast, but I have another issue that suddenly started happening.
Checking to see if anyone else has this issue, or if there's a fix,or even if it's a known problem.
My auto-rotate stopped working. Was working fine the last 24 hours, give or take. Which is the duration of how long I've had the device.
I checked all the settings, and googled around, so I restarted my phone, now it works again.
Didn't know about the diagnostic tool until after I rebooted the device and it started working again.
If it stops working, I'll definitely run diagnostics.
But until then; known issue? Anyone else experience the same thing? A permanent fix?
-voltagetweak
The update to Android 6.0 is planned to be released before the end of this quarter.
With adaptive brightness/contrast, do you mean what's discussed in this this thread? This is also fixed in the 6.0 update.
The the rotation work without the GPS running if you restart to safe mode?
Thank you Rickard for reply..So you are saying that this is a Software issue not hardware?
I'll wait until March 7th... that's the date that sony pretend to release Marshmallow to Z5, Z4 Tablet and Z3+.
So if is a software issue than ill have to wait..
I was thinking it was a hardware issue since when auto rotate stops, both Gyroscope and Accelerometer fails.
Thank for you Support.
I'm afraid i can't say for sure if what you are seeing is software or hardware related. What you are describing is a bit different from what i've seen in other cases where a restart helps.
If possible, i recommend that you wait for the Android 6.0 update as it will have a fix for auto rotation that sometimes stops working and see if that helps. But if it should still remain after the new update i think you need to contact a service centre or your Local support for further investigation of your unit.
From what you are describing in your previous posts, the software update should help.
I don't have any date for when the update will be released and software rollouts are a phased process – timing and availability will vary by market and/or operator. The rollout is planned to start before the end of this quarter though (before end of March).
