The mobile detects the USB but is unable to perform the file transfer. I tested it with 2 USB and it happens the same.
GT
Translation via Google Translate:
The USB in the computer works perfectly, the problem is that although the mobile recognizes the USB does not allow me to copy files.
El USB en el ordenador funciona perfectamente, el problema es que aunque el móvil reconoce el USB no me permite copiar archivos.
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
When connecting your phone via USB, did you choose "Transfer files" option?
Hello. Also a problem with the NEW Sony XZ F8331 phone. When connected to a PC, Windows 7 64bit, it says there is no phone connection. The cable came bundled with the phone, there is a charge. Data transfer to PC - no. On the phone: settings / usb / enable data transfer / © - no result. Sony backup program - “no phone connection”. What other options are there, can I replace the cable?
Здравствуйте. Тоже проблема с НОВЫМ телефоном Sony XZ F8331. При подключении к ПК, Windows 7 64bit, пишет нет подключения телефона. Кабель шёл в комплекте к телефону, зарядка есть. Передача данных на ПК -нет. В телефоне: настройках/usb/включить передачу данных/© - результата нет. Программа Sony резервного копирования -"нет подключения телефона". Какие ещё есть варианты, может кабель заменить?
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Could you try a different USB port?
I visited all four usb ports (1xUSB3.0, 3XUSB 2.0). I even bought a new USB-C cable. There is no result. Windows7 / Control Panel / Device Provider / [!] F8331. DRIVERS ARE NOT INSTALLED FOR THE DEVICE (CODE 28).
When connecting an old Sony C1905 phone, there are no problems at all. The program is installed and running.
With the new Sony XZ F8331 and with its new Sony “backup” program, it does not work properly. I did not expect such a catch from the famous nonsense like SONY. You at least checked the operation of the device before releasing it to mass production. Even the car manufacturer TOYOTA withdraws its cars if there is a problem.
I guess the problem is with the Sony “backup” program, or with the Sony XZ F8331 phone.
