Hi all,
I am facing one issue for my xperia xz2. That i cant change the themes for my mobile. Even i try to change using xperia assistan and it crash.. Any one facing same issue or have any solution please let me.
Desde la última actualización no puedo cambiar de tema del teléfono descargo y no puedo usar ningún tema
Since the last update I can not change the subject of the download phone and I can not use any theme
-GT
It works Thank you!
Hello how did you solve the problem with the themes I am on the same situation that I cannot change it I cannot see the themes option anymore
Thanks
There are 2 ways to get theme option back
Reset all aap or do Factory reset option. The only thing is you have to re-enter all the data after the App reset. If it doesn't work then you have to go with factory reset option
@Fertexas wrote:Hello how did you solve the problem with the themes I am on the same situation that I cannot change it I cannot see the themes option anymore
Thanks
Thanks
