Theme change issue
AzeeZ3
Theme change issue
Hi all,
I am facing one issue for my xperia xz2. That i cant change the themes for my mobile. Even i try to change using xperia assistan and it crash.. Any one facing same issue or have any solution please let me.
23 REPLIES 23
Madism
HI, I'm having the exact same issue.. Every time I choose and install a theme it just disappears from the menu ( yes, a default theme). It seemed to be a disabled app issue at first, because I had an app disabled, after enabling it:after installing a theme it dissappearrd from the list, but this time at least it applied to the home screen and seems to be working..
Still having the issue of the themes disappearing after install.
AzeeZ3
Any one found the solution for this issue?
Bnl
I've made a factory reset. That's the only way I've found to solve that issue.
Slightly_frowning_Face
profile.country.RO.title
sebikorek
New
Hi! The only solution that comes into my head is only the factory reset one. I believe that during the last software update something might have gone wrong and its causing this.
You can either connect your Xperia to the PC and select software repair in Xperia companion or do the factory reset directly on the phone.
SDR1970
So a firmware update is not likely to fix this then?
RizkyRizz
I get same issue, anyone solve this problem without Factory Reset?
AzeeZ3
I think there is no solution apart from factory reset and Right now Sony is focusing on Android 9.0 so might be we are  not receving any firmware update. For this issue.
markiepuk
Explorer
I had theme issue on Oreo and Pie downloading new ones or choosing installed ones didn't work, update didn't fix issue. I reset all app preference (app settings/show all apps the click menu in top right an reset all apps) worked for me (But all app permissions need to be granted again) but saved a full reset!
AzeeZ3
Thanks . I tried and its working fine.
SDR1970
Worked a treat  Thank you
