"Add location" pop up when open camera
SACH1
After  update to android 8.0, when I open the camera app there pop up "add location" that remains permanent and I can't use camera.
profile.country.PL.title
najodleglejszy
13 REPLIES 13
najodleglejszy
@SACH1 can you take a screenshot of the pop up and post it here?
Cosma
Same in my case. Message keep popping up.
najodleglejszy
@Cosma have you tried clearing Camera app's data? you can do that by going to Settings > Apps & notifications > Camera > Storage > Clear data
Cosma
Yes! Still the same! keep popping up! Only the app has issues, other apps use the camera flawlessly.
najodleglejszy
@Cosma you can try booting into safe mode to see if anything changes. if the issue persists, your best bet will be to perform a software repair using Xperia Companion.
Cosma
Thanks! Tried also the safe mode. Same  happened! I would give a try with repairing software. It is really annoying.
Entigo
I have the same problem have you sorted it out yet?
najodleglejszy
@Cosma let me know if software repair fixes that.
Entigo
Have you fix it yet please got the something
