Z5 compact headphone volume up, system ui problems
dp2
Hello when I try to turn my volume up on mii phone when my headphones are plugged in mii system ui pops up saying it's not working & then locks my screen. Deleted mii background too, but I kno that's because my system ui not working. Is there a fix for this??
9 REPLIES 9
profile.country.PH.title
MarlonUk1
can you take a screenshot if this problem shows up?
try to clear smart connect app
settings>apps>smartconnect>clear data
also try to clear Xperia Home
settings>apps>Xperia home>clear data
Tags (1)
Emir1
Hero
Hi @dp2,
I am sorry to hear about that.
First I would suggest that you troubleshoot the way @nolramlb suggested, but in addition you may also try to see if the same happens in safe mode. Let us know how it behaves once you've tried that.
dp2
I cleared out both apps like you suggested, no difference, even restarted my phone so it would stay. But I have noticed that I can turn the volume down and then when I try to turn it back up it will only go to the halfway point. So I went to the smart connect app and went to settings and turned the volume all the way up so when I put my headphones back in the volume will be louder. Still no difference 😥. When I try to go past the halfway point that's when I get the ui pop up message and my phone blacks out. I did take a screenshot of it. I'm not sure how to put it in here though. I'm getting ready to try safe mode.
dp2
Just tried the safe mode method & the same thing happens. System ui message pops up & then turns mii screen off. I'm guessing this is something Sony did w/the phone to prevent too loud of music thru headphones. Do u have this problem, can you go more than halfway up your volume rocker while your headphones are plugged in??
Mimi666
I have the same problem!! It's so annoying.... I'm hoping they are going to do something about it Slightly_frowning_Face
Mimi666
And the funny thing is it didn't happen straight away but a week after the update...
Bugmenotsony
Yeah you just should post your screenshots for clarification.
Algxen
The same happens to me, I'll see if I can post a Screenshot
Algxen
Here are the screenshots:
