when I call someone I listen well all normal, but when active speaker on the call does not listen to me, and if I speak my voice is heard and starts a loop sound of my voice and starts sounding stronger, the other person you can hear me. I tested in safe mode and as usual, it was after the last update 26.3.A.1.33. as I can solve.
sorry, use google translator
Repair the phone with XC and report back
Same thing happens with my E2206 M4 Aqua build 26.1.A.3.120, and also my XA Ultra. When I press speaker I can hear them, but the other person can not hear me.
pressefr
Use xperia companion, but the problem persists, another solution can help me clarify that was after the last upgrade xperia aqua 26.3.A.1.33 m4. well the problem is when I make calls whatsapp, if I put speaker will not hear me, but regular headset and handsfree works very well, but no speaker, it can be?
utilize xperia companion, pero el problema persiste, que otra solucion puede ayudarme, aclaro que fue despues de la ultima actualizacion del xperia m4 aqua 26.3.A.1.33. tambien el problema esta cuando hago llamadas por whatsapp, si pongo altavoz no me oyen, pero manoslibres y auricular normal funciona muy bien, pero en altavoz no, que puede ser?
