Hai Xperians
My Z1 was 1 year old. It perfromed well, I am in 4.4 now.
When connecting phone to wall socket charger, it shows charging and level increasing. After few minutes it stops charging and starts again. Then orange led flash, do charge and stops within second and repeated the same dranstically. This continues till the battery drained if unnoticed.
It was charging slowly in USB connection through computer
Charger have no issues, i checked it with other phone.
After reading similar articles tried Power button + Vol Up for force shutdown. Conneted to wall socket charger and it was charging. I have checked few minutes interval, found no issues. After an hour when i noticed it stopped charging. Switched ON the phone found it was drained (LED turns red). Hopeless on the solution.
Please help me on this
Ya the same issue happend for the new charger too.
Tried wall socket charger
Now i am using same factory supplied cable in laptop and desktop. No issues
Its happening only in wall socket chargers. Why ?
I suspect on charger- but charger working on other phone
I suspect on USB cable &/ usb port - Same cable of charger works in PC and charging without any issues( Only problem is slow charging)
But this cable was good with PC , charging but slowly
That's quite odd, you could contact Sony directly
@Phy
I tried all solutions posted in forum, except factory reset. which i am going to do now.
@uliwooly
I have emailed to sony. They are in stage 1. (try another charger)
