Xperia T Jelly Bean Problems
Kaiju2468
I have just recently updated my sony xperia t to android 4.1.2 and Now there are many problems:
  1. The battery drain is just mental, it only lasts me a day, whereas with android 4.0.4 it used to last me over 2 days easily
  2. The 'improved' walkman app is just plain rubbish, most of the time when you are listening to a playlist it just will not go onto the next track. You have to press the power button for it to play the next track
  3. The 'smoother' interface in now so rubbish, the is quite a bit of lag in the swipe of the homescreens, whereas with android 4.0.4 it was silky smooth
Can someone please help me?????
32 REPLIES 32
Rickard
First check if you have installed any task manager/killer in your phone and if so, try uninstalling it. When the music player stops in standby it can be a task manager that's killing the process. A task manager can also cause a higher battery usage. If it's not a task manager, have you checked what's using the battery under Settings -> Power management -> Battery?
We got some feedback in another thread that certain widgets like the weather widget can cause some small lag on the homescreen in the new update.
Kaiju2468
Thanks for your reply, but I do not have any task killer/manager apps running. Also just today, I disovered that once you listen to music via headphones, than take out the headphones to listen to it on the loudspeaker, there is just silence, I can only fix this by turning the phone off anf on again.
Can Sony please release a patch to fix these problems?????
profile.country.IT.title
Ambros73
Member
I restored factory settings erasing everything on the phone before AND after the update but I have the same battery drain problem!!! With the phone fresh from update/factory reset it lasts less than 10 hours instead the 16/20 before JB update 😞
Ambrogio Calcaterra
Rickard
I checked and after an update you may notice a higher battery usage for a while. Please use the new software for a week or so and see if it gets better.
Regarding the Walkman app i'll try to replicate the problem and forward this as feedback.
Kaiju2468
Please can Sony release a fix to these problems as soon as possible. This phone was perfect before the update
eddymjj
I've got the same problem with the Walkman app. I solve it Chen I desable Smart Connect. It's this app witch need updates with Jelly Bean.
Regards.
Kaiju2468
Thanks for the advice. I had disabled smart connect, but the problems are still there....
Regards,
Kaiju2468
I have tried a factory reset and I have reinstalled the software and the problems are still there, please can sony release a fix soon?????
Kaiju2468
The battery life is now shocking again, just took the phone off the charger this morning an hour ago and the battery has already gone down to 98%, without doing anything!!!
