Xperia Pro MK16i stuck in boot-loop (showing Xperia logo only)
Ryoushi
I owned an Xperia Pro bought on Feb 2012, and running ICS updated by PC Companion.
It keeps restarting/rebooting (symptom very similar to http://talk.sonymobile.com/thread/51181) after turning on bluetooth today, showing repeatedly only the Sony logo and the animated Xperia screen.
This phone has NOT been rooted, NOR unlocked the boot loader.  It is using the latest firmware available in my region as of today (4.1.B.0.587).
I tried starting the phone with/without the SIM card and/or SD card with/without USB cable but NONE of the combinations helps...
It was set to Mass Storage Mode, so it could NOT be connected to PC Companion for software update.
I am wondering if it is still possible to rescue the data inside (contacts, SMS, etc.), by for example, flashing newer firmware from uliwooly, or send to Sony for recovering.
Thanks in advance for any suggestion.
Here's the ADB log when booting until it restarts automatically and re-enters the boot-loop:
01-06 08:02:42.482: INFO/bluedroid(299): bt_enable: ret: -1, errno: 19
01-06 08:02:42.622: INFO/bluedroid(299): bt_enable: ret: 0, errno: 19
01-06 08:02:42.622: INFO/bluedroid(299): Starting bluetoothd deamon
01-06 08:02:42.622: ERROR/BluetoothEventLoop.cpp(299): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 08:02:42.622: DEBUG/dalvikvm(299): GC_CONCURRENT freed 678K, 6% free 12904K/13639K, paused 3ms+26ms
01-06 08:02:45.652: DEBUG/BluetoothA2dpService(299): A2DP state : device: 40:2B:A1:5F:DB:9B State:0->1
01-06 08:02:45.662: DEBUG/BluetoothService(299): CONNECTION_STATE_CHANGE: 40:2B:A1:5F:DB:9B: 0 -> 1
01-06 08:02:45.662: DEBUG/BluetoothA2dpService(299): A2DP: onSinkPropertyChanged newState is: 1mPlayingA2dpDevice: null
01-06 08:02:45.662: ERROR/AndroidRuntime(299): *** FATAL EXCEPTION IN SYSTEM PROCESS: android.server.ServerThread
01-06 08:02:45.662: ERROR/AndroidRuntime(299): java.lang.RuntimeException: Error receiving broadcast Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x10000010 (has extras) } in android.server.BluetoothA2dpService$1@2c0f4fe8
01-06 08:02:46.162: INFO/Process(299): Sending signal. PID: 299 SIG: 9
01-06 08:02:46.212: WARN/dalvikvm(514): threadid=1: thread exiting with uncaught exception (group=0x2b542210)
01-06 08:02:46.222: DEBUG/kernel(140): [   34.552246] binder: 471:471 transaction failed 29189, size 60-0
01-06 08:02:46.222: ERROR/installd(135): eof
01-06 08:02:46.222: ERROR/installd(135): failed to read size
01-06 08:02:46.222: INFO/installd(135): closing connection
01-06 08:02:46.242: WARN/AudioFlinger(148): Thread AudioOut_1 cannot connect to the power manager service
01-06 08:02:46.252: ERROR/AndroidRuntime(514): FATAL EXCEPTION: main
01-06 08:02:46.252: ERROR/AndroidRuntime(514): java.lang.RuntimeException: Unable to create service com.google.android.location.internal.server.NetworkLocationService: java.lang.RuntimeException: Package manager has died
(Edited fireware version and message title by Ryoushi)
13 REPLIES 13
Madaditya
Try using 'Bluetooth file transfer' from the market, and see if it solves your problem
Ryoushi
The phone just rebooting continuously and never even gets to the home screen.
Johan
I suggest that you try to run a software reinstall using SUS.
If the problem still remains you should contact your local support team, to have the phone examined and fixed at an repair center.
Flamewing13
Met ur so called "authorized service centre"
Said & quote "it seems to have some problem with display or strip wire " cost
3000 for strip wire+3000 for display= 6000...
First we ll change stripe wire.. If it's not still working .. We ll change display too..
Asked em again.. Ll t function after I spend 6000??
Epic reply "that !! We can't say for sure"
Oh yeah!!!
M gonna spend 1/3 of my mob's price for nothing!!!
Flamewing13
NOT!!! 😛
prachi5190
I am facing the same problem with my Xperia Pro since last week. I tried to connect it with my PC with unable to do that too.
Please help me with something.
profile.country.RO.title
_alexdon_
Use sony update service to repair:
alexdon
Rajenndraa
I am facing the same problem. It hit when I tried sharing a few files over bluetooth. And its now cycling between the sony and the Xperia logo.
_alexdon_
Try the update service and repair.
alexdon
