my sony pc companion stuck on preparing and keeps restarting while updating on lollipop
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
thanks for the reply but i forgot to mention that my phone or pc is not restarting its the installation that keeps restart every time when it reaches to preparing
Disable any antivirus and/or firewall and try again, if that doesn't work, try with a different computer.
Also try using a different USB port and/or cable if possible. You could un-install & re-install PC Companion before trying another computer as well.
There's no problem with the phone cable or anything, it's update error
Could you please upload the PC Companion logs and send the link to me in a PM?
PCC logs can be found by:
* Right clicking PPC in the notification area of the task bar (if the notification area is full it can be found when clicking the "Show hidden icons"-arrow)
* Chose About Sony PC Companion
* Click on the link in "Click here if you want to dump logs to Desktop"
* Go to Desktop and find PCC logs in zip-file.
PCC logs are saved on the user’s computer for 5 days so, meaning normally there’s no need to reproduce the issue to retrieve the logs.
Hi zaheado1
Have you tried temporarily disabling anti virus/firewall software and then tried again?
I see. Are you able to access a different computer? If so, I advise trying to run PC Companion on another computer.
