Pressure test
JChang97
Pressure test
I am trying the pressure test with pressure sensor to test it's waterproofing or not
The value doesn't goes up when I press the panel and the value dropped by one when I release
Then when I hold the three holes at the bottom and press again, the value goes up by 5-6
It is normal the value doesn't raise if I didn't close the three holes?
3 REPLIES 3
Samuel1
Hero
How are you performing this pressure test?
Samuel1
Hero
If you want a reliable pressure test the only way is to send in the phone to a service center. The phone should however be tested from factory so if it's new it's not necessary to test.
The service menu is not intended for end users.
