SD card. I have removed it without unmonting it .
Videoproblem
As said, I have removed the card without unmonting it, I didn't kniw I had to do it. . So now it seams nothing is there but it also seams with 0 space available... Provably is corrupted or...what can I do? My phone is a Xperia 4 aqua
6 REPLIES 6
@Videoproblem
You will have to reformat the SD card. try to test it with a different phone or computer
Lord_viridis
If you have access to a pc and SD adapter, try running a disc check on the card with repair option enabled
atom2
I want all my application again
@atom2
if you had apps on the SD card, you will have to redownload them.
Videoproblem
Hi everyone who kindly replied to me. I've followed your instructions. Thanks. All sorted. I'm just 'sad' that this phone has so little memories. Not everything can be moved in the SD card, and almost half of the phone memories is taken by the phone system. So many things I don't use can't be removed...and many can't even be updated. Next time I'll buy a phone I need to make sure it has lots of memories. Anyway...thank you!
valyo_bg
New
Don't worry, after update to Android 6 you will have possibilities to move everything to SD card. Then you will have free space on internal memory. Hopefully this month M4 Aqua will receive update to Android 6.
