I am facing anissue with the proximity sensor control over my screen display during a call.
My phone screen goes black (due to the proximity sensor) as I start a call and doesnt turn on untill the other person ends the call.
Please provide any suggestions for avoiding this issue. (It has already cost my phone balance a lot.)
Thanks in advance !!!
1.Check if the same occurs in safe mode:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
2.If the same is in safe mode,do you have a flip case or thick screen protector?
Settings-apps-all-incall ui,enable it.
There is nothing such as "incall" in my settings.
In this case, settings-personalization-manage notifications-tick phone. If this does not work either,tell us.
Phone notifications were already on in that list.
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
I am still experiencing the problem again and again.
Any other alternative ??
Thanks !!
