Xperia Z2 writing skips while charging
pdes1
I have tried to write with a Jot Pro on my Z2 tablet with 4.4.4. installed while charging.  Strangely, I discovered that the stylus started skipping to the point that writing was impossible.  As soon as I removed the charge lead, everything returned to normal and writing was OK. I tried this on a number of apps and all had the same issue so the problem has to be with Firmware.
Has this been recognized as an issue?
Thanks
5 REPLIES 5
That could be a compatibility issue, contact jot pro directly
pdes1
...But it works OK when not on charge so can't be compatibility.
Does the screen work fine while charging (using your fingers)
pdes1
Interesting!  Works ok with fingers while charging!
What's also interesting that not other stylus worked properly while the tablet was on charge.
aesics
Had same problem once using a third party charger and once using a charger from HTC even while typing with fingers. Try this: turn the plug(at the wall socket) in order to 'change' polarity. This worked fine with the HTC charger @ my Z2 tablet.
