Problems updating to Lollipop
Mozness
I need help updating my phone to Lollipop. I have the latest PC companion installed and I get to the step where I need to hold down the volume key while inserting the usb cable. A red light flashes and then nothing.
4 REPLIES 4
profile.country.RO.title
_alexdon_
Have you completely turned off the device before connecting to computer? Do you have any antivirus or firewall that could block the update?
alexdon
Hampus
Also make sure that your battery is fully charged or at least 80% charged. And when you are connecting the phone, hold down the volume down(-) button before you connect it via the USB-cable, and don't release it until PC Companion goes to the next step.
Mozness
So now I get two things that can happen:
A) Nothing or
B) A battery charge indicator.
What do I do now?
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
