- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Problems updating to Lollipop
I need help updating my phone to Lollipop. I have the latest PC companion installed and I get to the step where I need to hold down the volume key while inserting the usb cable. A red light flashes and then nothing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have you completely turned off the device before connecting to computer? Do you have any antivirus or firewall that could block the update?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Also make sure that your battery is fully charged or at least 80% charged. And when you are connecting the phone, hold down the volume down(-) button before you connect it via the USB-cable, and don't release it until PC Companion goes to the next step.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So now I get two things that can happen:
A) Nothing or
B) A battery charge indicator.
What do I do now?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
