I have xperia j but the touch screen hang many times a day, i cant pick my calls or i am unable to draw a pattens or swipe the screen. I use my phone without memory card and I also upgrade my phone software, but the problem is the same...very bad experience with Sony..
Use this program SEUS, use force upgrade firmware for phone
Thank Jithin191.. its working.. my xperia j no longer have the hang problem with the screen.. and i hope the problem will never come back... Love your post!
My phone also have touch problem. now i use slide screen lock to lock my phone.because Patterns is not work correctly. what am i do now??
and when i touch smething it is take more time 2 open
please tell some solutions
Law91
wat u do to solve ur problem?????
please check out solution for screen lag problem -http://chitotechexpress.wordpress.com/about/. 100%working to my xperia j.:)
Hey Guys how are u all i would like to share a problem which i am facing with sony xperia j sometime after receiving a call the touch sound and when i play song the sound is too low which i can't even hear it just seems there is sound but ver low first time i thought the volume has been decreased automatically but the volume is full still don't know what's going on ever what app sound there is a very low beef only
Hi, I'm having same issues just yesterday. The touch screen is malfunctioning, I cannot even unlock my phone using the pattern lock, and even navigating inside the phone seems nearly impossible and its really annoying. I just bought my Xperia J a month ago.
I tried reading several forums and tried the two most common suggestions:
1. UPDATE THE PHONE TO THE LATEST FIRMWARE. After the software update, there's not much significant changes. Screen response is still laggy, though there's a little bit improvement in the touch screen. But not much changes.
2. USING THE CALIBRATING APK. I tried downloading the app and then installed using MobileGo (i tried installing in the internal/external), but when I tried running the app after the installation, it returns an error saying that the app stopped working. I also tried restarting the phone after the installation was finished, but still no luck. Am I missing something?
So, in the end, my problem wasn't solved by these two "solutions" that seemed to worked for everyone.
Here's my Xperia J's additional info just in case you need it for analyzation:
Model Number: ST26i
Android Version: 4.1.2
Kernel Version: 3.4.0
Build Number: 11.2.A.0.21
Debugging Mode: Enabled
Unknown Sources: Enabled/Checked
Any help will be much appreciated. Thank you.
Replace touch screen.
i have signal problem...
i'm using the malaysia network..
cannot get the signal at all
