Problem to update my cell phone (Xperia Arc LT15)
I have a problem to update my phone. as you mentioned in your website, i used Sony Ericsson PC Companion to update my phone. but, when i get to prepare section (Preparing software for updating), it was stopped and i face with following error:
unable to install or start phone software update components
Would you please help me?
I am confusing...
9 REPLIES 9
slimshaddy
Hero
update your phone with this..
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
this is an official sony software so don't worry..
mark helpful and correct answers..
it doesn't work.
i have downloaded the pc companion and i start to update my phone, but in second stage of updating(2.preparing) , i face an error:
and then updating will be stopped.
Can someone let me know how to update my Xperia Arc (LT15) from build no. .42 to .62, step by step?
PC Companion its NOT the same as SEUS, the link above its for Update Service.
install it, restart your PC, run it, and make sure your antivirus and/or firewall are turned off
Update Service (SEUS)
You might not need to backup everything but I wouldn't risk it so
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
SMS/MMS/Call Logs
Install "backup SMS+" to back up your SMS, MMS and Call Logs  to your Gmail
or just SMS use
"backup & restore SMS"
or just MMS use "Save MMS"
Call Logs (Just call logs)
Contacts
open your phonebook
on your computer
Backup & Restore app (will backup your SMS, MMS, Call Logs, Settings, Apps, Contacts)
Use one of these links to download the
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
download the app, transfer it to your SD card
Download Apk Manager
https://market.android.com/details?id=com.magmamobile.app.apkinstaller&hl=en
open "Apk Manager" and voila select the apps that you wan't to install
Apps
Don't worry so much about backing up your apps
on your computer go to: market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
Make Sure to mark the Correct Answers & Helpful Answers
How to sideload apps
1st Method
How to install it
You need to
download IO File Manager
download the app on your computer, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
2nd method
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
3rd Method
BOX and upload the apks from any computer
install the App on your phone -> open BOX -> tap on the app -> install it
4th Method by far the easiest
an even Easier alternative
Markus1
Leader
Try Update Service and see if it works better (like Uli said, it's not the same software).
If you don't have this option or get the same message, have a look at running processes in the PC. It's quite common that fire walls and anti virus software can block PCC, causing this problem.
Yes, the issue is resolved by update service.
LBH
Can someone help me... I ve trobles with the 4.1.b.0.431 update 1 stage I accepted but in the 2nd stage the preparation fase it fails and says some componets couldent be started and then the update stops so I cant get to stage 3 en 4 in the update .... Can some help me thx!
Nabeel
Use this
________________________________________________________________
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
Both the links are same
Quazer
I can't update, but with a different problem.
When using both the PC Companion and Update Service, both work without bugs,
but there's one problem :
They both say my phone has the latest software installed on it, which it OBVIOUSLY doesn't.
It has Android Version 2.3.3, it's the Sony Ericsson Xperia Arc LT15a, and I honestly don't know what to do!
Build number 4.0.A.2.368
