Phone shows that headphones are connected when they're not
pavithran
i bought xperia zr and i have not faced any till last month but now my mobile earphone socket makes trouble.eventhiugh if i didnt connect my headphones it will show that i have connected so that i cant hear anything in speaker(phone internal speakers) and even in calls now i am using loudspeaker mode for answering a call
. could anyone face this kinda problem.please help me and thanks in advance
Topic edited by Rickard
7 REPLIES 7
Thommo
Genius
Try Settings - Apps and swipe to All then locate and open Smart connect and tap on Clear cache and clear data then reboot and test
pavithran
Thanks for your comment but this didnt work buddy tried it twice
profile.country.RO.title
_alexdon_
Settings-apps-all-sound enhancements,force stop and clear data. Also,try to unplug the headphones while in a call or while listening to music. Repeat the process several times.
alexdon
pavithran
NOPE its working guyz tried for 2 days again and again Zipper-mouth_Face
Spoiler
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
pavithran
thanks fa ur advice buddy i go for it now
brett_jhb
Did that work? I have the same problem but don't want to go through this for nothing...
