i bought xperia zr and i have not faced any till last month but now my mobile earphone socket makes trouble.eventhiugh if i didnt connect my headphones it will show that i have connected so that i cant hear anything in speaker(phone internal speakers) and even in calls now i am using loudspeaker mode for answering a call
. could anyone face this kinda problem.please help me and thanks in advance
Topic edited by Rickard
Try Settings - Apps and swipe to All then locate and open Smart connect and tap on Clear cache and clear data then reboot and test
Settings-apps-all-sound enhancements,force stop and clear data. Also,try to unplug the headphones while in a call or while listening to music. Repeat the process several times.
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
thanks fa ur advice buddy i go for it now
Did that work? I have the same problem but don't want to go through this for nothing...
