I can not connect phone to PC. A week were not problems but now the phone is charging only.
I tried all possible:
I realized that the problem is with the phone software.
Currently found your update to ICS, but how to update when I need a connection to PC
Please help
Have you tried un-installing PCC rebooting then re-installing - It could be something as simple as that
Do you get any response from the phone and/or the PC when you perform the connection?
Yes, i made this several times and no result
PC dont recognize the phone, just charging
did you turned off your firewall and antivirus?
when you connect your phone to your computer does the LED turn on at all?
try my suggestion w/o antivirus and firewall
I tried to close the firewall, I tried other 3 PC and no result. I connected a PC Xperia X10 and immediately began loading drivers. The problem is as I said into the phone.
can someone upload all the folders that are in the phone software to copy them in mine and try again?
I've had this constantly since .75 was released. The phone just will not reliably connect to the PC. Sometimes I find you have to open 'devices and printers', remove the Xperia S and connect the phone again. It fails to install the driver then disconnect the phone and reconnect again and about 30% of the time it works!
I have to be honest but this is the single worst device I have ever connected to my PC. It takes literally a dozen attempts to get it working each time, by which point I have forgotten why I am connecting it!
which folders?
check this thread
http://talk.sonymobile.com/message/239634#239634
