My Z1 Compact taking more than 3 hours to Charge Completely, Which is almost 2 times it takes on my Xperia ARC.
I don't think it's usual. Please let me know how to overcome it. I am using the original charger
Hi
At the top, I have Screen Process using 55% and then Android System using 8%.
Screen is not an issue while charging as I usually turn off my phone while charging. Also I am not facing any battery drainage issue.
Can it be any hardware failure? shall i visit nearby service Centre regarding overheating and chrging time?
I have tried charging my phone on Safe mode as well, But no help :S
Yes,you should stop by a sony service:
I have the same problem. The phone takes over 3 hours to charge and I think that the battery drains faster than on my wifes z1 compact while using the phone but it seems to be fine in standby mode. Could it be a faulty battery that can't handle higher current well? I have already sent my first phone away to get a new one because the SIM-card reader wasn't working on my first phone. I don't wan't to send my phone away again because of bad quality control from sony.
Please share if your phone will be repaired or if it's something else causing the problem
I am still waiting for some relevant information / Help from Sony Executive.
@AnkitManocha - Have you followed the advice provided by Alexdon above?
