My Z1 Compact taking more than 3 hours to Charge Completely, Which is almost 2 times it takes on my Xperia ARC.
I don't think it's usual. Please let me know how to overcome it. I am using the original charger
Well, it all depends on what's running on the phone. Does it still take 3 hours when the phone is turned off and you charge it?
Have you tried any other chargers to see if the charging time is the same? I can't really tell how many hours my Z1 Compact takes to charge as I plug it in when I go to sleep.
Look at the output of the charger,how many Amps/hour are there?
Also I have noticed that my Charger as well as my mobiles gets heatup while charging.
While charging, Mobile battery Temperature changes from 32 to 41-42 degree in 30 minutes only.
Though i have not faced battery drainage issue but 3 hours for chargin phone is totally unacceptable.
Please provide a workaround or solutionfor this.
Perform a software repair on the device and check if the same occurs:
Hi
I have already tried that, but no help..
That is odd as this indicates something is using a lot of power whilst on charge. If you check the Battery Usage section of Power Management in Settings what are the top couple of applications/processes listed?
