i constently get the message of '"this application, unfortunatly stopped"'
i tried to format the mobile twice but the problem still exist
please help
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
