Lock screen lag.
Libra7
Lock screen lag.
i will forgotten my sony xperia miro`s screen lock pin..how i can recover this??????
please,help me.......`
profile.country.RO.title
_alexdon_
If you do not have internet enabled,your only shot is the next one. You need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
