My sony xperia z2 unfotunatly stops everything
omarabdelwarith
i constently get the message of '"this application, unfortunatly stopped"'
i tried to format the mobile twice but the problem still exist
please help Grinning_Face
2 REPLIES 2
amraboelsafa
from a certain app or all apps?
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
