Hi
I am having trouble with the call volume when using the louspeaker.
Seems to only use 1 of the 2 speakers?
I have tweaked the all the setting including the equalizer which has improved the head phone volume but had no effect on the loudspeaker. When talking normaly the volume is ok but could also be louder
does anyone have any ideas
thanks
It's amazing how Sony just skip this problem ! The phone is almost useles since the voice pressure/volume via speakers are way too quiet..
I have the same issue, did any of you send the phone in for repair, and did that fix it?
An Sony response would be appriciated.
Why is no-one doing anything about this? The mobile's are clearly flawed? Mine is less than a year old, it's disgusting.
Hi
When I talk with my mobile(Xperia Z3 Compact) witth speaker I has bad voice, noise and cut voice. WHY?
Hey I fixed mine!
The rear glass panel had also started to lift slightly at the bottom, so using a little heat and a guitar pick, I carefully removed the glass panel and found there is a plastic surround underneath which presses the bottom speaker into it's contacts. On further inspection I noticed there were two tiny screwholes towards the bottom of this surround,, but NO screws!
I managed to find a minute screw the right size and fixed it into one of the empty holes which pressed home the speaker contacts and now it works!
Is this a just down to a batch of missing scews I wonder?
Any1 who needs bouth speaker to be in use while using speakerphone, root youre phone and instal zip from xda developer forum...woarks like a charm...all recommandations from me.
My headphone volume is also low after the lollipop update hardly can hear the person I'm disgust and it would be a nice phone Sony FIX THE ISSUE!
From the US
mi z3 compact sounds low when a speaker call, and when i listen music on speaker, the upper speaker sound more higher than the down one? its this normal? its mi second z3 compact (d5803 and d5833) and both are the same. i cant listen in a call with speaker its too slow sound. thanks
